Electrical Car tries to start when pushing in clutch
derek1993
162
79
38
Thompson's Station, TN
Getting everything back together on the 93, pushed in the clutch to spin it over and the car tried to start before turning the key.. it will do the same without the key in, I didn't disconnect anything but did have to disconnect all running to the starter solenoid to move it a bit.. i don't "think" I hooked up anything incorrectly, but I could be overlooking something. Anyone run into this before? I'd like to clean up all that is going to the starter solenoid(so many wires), but want to get it running again before I tackle any rewire.
thx
How can you say you didn't and did disconnect things in the same sentence !!
Without crawling around the car I would think you have somehow connected the clutch interlock switch to the start signal on the solenoid. Which makes me think you have disconnected and connected more wires.
mistyped.. sorry boss. to 'correct'. i disconnected the wires from the starter solenoid in order to move it.. but didn't disconnect anything else.
@KRUISR , you pointed me in the right direction.. previous owner had made some wiring modifications.it seems. I have to get a picture of it, but the plug that the clutch interlock switch runs to isn't connected to anything.. however he had a wire with a ring terminal spliced/tied in that i had hooked to the solenoid. disconnected and works as expected. Need to figure out if it's a ground or other, will take a pic to see if it helps, as i'm not sure how it should be hooked up.
Thanks for the guidance
Hard to find a clean mustang these days mine included. Love the hotrods like mine but really like to see and work on the stock ones. You will get it back to stock or where you need it. You probably want to rewire a few things yourself anyway. Like the fog lights. They been melting connectors for years. You can fix old Chevys by putting ford parts on them.
  • Haha
Reactions: General karthief
Long ago in did the then mandatory wire tuck to hide all the wires in the engine bay. Worst thing ever. Every time I needed to check, move, or fix anything it was a nightmare. I'm a fan of making it look clean and neat but I'm not pulling the wheels off and the inner fender liner every time I need to check a wire!
I’ve wondered about that. Thanks for the warning.
Reactions: Wayne Waldrep
thx
Follow the wring diagram to find and fix your problem...
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachments\64167
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachments\21328
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachments\52294
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachments\53216
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Reactions: derek1993
attachments\64167
100 mV Ground
0.0V Connections
attachments\21328
attachments\52294
attachments\53216
Great information, thank you. The wire that was in question needed to be grounded, i'll trace back what the plug is that the previous owner had left unused and tied the ground to it to see what the function was. All looks good for now, need to get it aligned and i believe an exhaust leak has appeared.. not sure if that is related to sitting for so long, but will poke at this week.. have to find out where a new 'whistling' noise is coming from as well.. if it's not one thing it's 4...
