Car won't start
I have a 1986 Mustang LX with a 3.8L V6 with Throttle Boddy Injection.
I can't get it to start,it cranks and cranks,but won't fire up.I have spark,I have air...it's some type of gas issue.It "explodes" inside the throttle body.
ANy suggestions,because I am totally lost and now I am vehicleless.
Make sure when you turn the key to the on posistion (not start it), see if you can hear a hum comming from the rear of the car. If you dont, then that means the fuel pump isnt kickin on. Make sure the fuel shutoff switch is reset, I had a problem like that on my 89.
If there is water in the tank wont it set to the bottom that’s where the pump sucks fuel/water from? (pretty sure) ask if anybody else had problems with that station.....if so I believe there is something you can dump into your gas tank that will fix that ask your local parts store. Its like alcohol or something crazy, but its safe. ?Anybody?
