Ok so i want to get a general idea of what mpg i should be getting with my current set up.
Car is carbed with a 650 edlebrock avs2, 355(i think) gears, with a 4CYL t-5. I hate this trans for alot of reasons but its what im stuck with for now.. anyways the car feels awfully geared id say similar to a 4.10 fox but not quite the same. It has basically no first gear, it can idle its way up a mountain in first nearly
. And at 65mph it sits at 24-2500rpm and 2700 at 70. So i drove about 60 miles on 10GALLONS and really didnt drive it that hard and it was just about empty(fuel gauge is dead btw). Avg of around 7mpg
. But about half of that drive i had a older edlebrock on it since this one needed to be cleaned so i cant be sure what the real mpg this current setup is getting. So i filled it up and cruised home about 30miles at 60-65 (2200-2500rpm)and filled it up again and calculated 15mpg. Is this all i can expect to get from this setup? I have heard of others with this carb getting 20-28mpg
. And does the difference of say 2300rpm vs 2800 really have such a huge impact on mpg? Thanks for any input!
, no but seriously mine was set to what the guy refers to as “hot rod mode” meaning more gas and i need to set it to “cruiser mode” to get better mpg. Once i drive it again I’ll update this if i saw any difference. Also i did adjust the idle air screws to as close as i could get it With a tach because i dont have a vacuum gauge yet but ill be getting one. One thing that wasnt clear to me is how to figure out if i need to change the metering rods. Anyways, it seems theres not a ton of options for better mpg as the issue is clearly i have to get a different trans/and or different rear gears if im gonna ever see 18+mpg..
