Carb vs. EFI and more 351w Questions
5ohMustang said:
OK, now that I know which 351w shortblocks are OK to use, I'd like to find out more about Carb'd set ups vs EFI. What does an efi set up require that a card'd set up doesn't and vice versa?
Thanks,
Brian
Basically carb setups are cheaper. I dont think that there is a real HP difference from carb to FI. A FI is more adaptable to different conditions and would drive better (economy and cold driving) than a carb.
Yeah...the Carb set up is the way to go if you're on a budget. They're actually been shown at times to produce higher peek horsepower over a similarily built EFI set up. Mind you EFI would be the way to go to retain as much low end torque as possible, improve overall driveability and make the best of your fuel economy.
If you are going to be using your current car, then the carb would probably be more expensive. The carb would need a new low pressure fuel pump, carb intake, carb. The EFI would need a new lower intake. Thats it. I mean besides the normal 351W swap stuff, motor mounts, oil pan, headers...and so on. But to convert a EFI 302 to a EFI 351W(or stroker) is gonna be less than EFI 302 to Carb 351W.
Later,
Mo' Town
Thanks for the help. I was planning on building up my 302, so I already have all of the following:
70mm TB
73mm MAF
TFS Heads
GT 40 intake
LT Headers w/ H-pipe
24lbs Injectors
1.7 Comp Cams RR
I also plan on ordering a custom cam and a 190lph fuel pump. If I have this figured out right, whether I went carb or FI, I would still need 1/2" fuel rails, 351 distributor, swap headers, swap oil pan kit, a different lower intake or a carb, a 28oz flywheel, flexplate, and harmonic balancer, and the accessory bracket. Only difference being that, w/ a carb set up, I could just sell the TB, MAF, and GT40 Intake. Have I got this correct?
-Brian
Pretty much. But remember that a carb uses a lower pressure fuel pump, and no fuel rails. Me personally I go EFI, especially since you alreay have all of the stuff for it. It's more tunable, it's better overall. No need to keep messing with the carb for street and track. But this is just my opinion. Others will give you theirs. All I can say is do what you think is best.
Later,
Mo' Town
70mm TB
73mm MAF
TFS Heads
GT 40 intake
24lbs Injectors
1.7 Comp Cams RR
-Brian
Why would you think that you need 1/2" fuel rails....how much power are you planning on making? Cause if so...you'd better get something bigger than the 24lb'ers and the 190lph pump while you're at it. The stock rails will work fine for what you sound like you'll be doing to it.
5ohMustang said:
A few of the pages/threads I have read said you can't use the stock fuel rails and recommend upgrading to 1/2" rails. This site (http://www.svtcobraltd.com/351swap.htm) imparticular says the stock fuel rails will not stretch over the lower intake (paragraph 5, about midway through).
Thanks,
Brian
All it is, is that little rubber fuel hose isn't long enough to connect the lines, so spend like 3 bucks and get a little longer one, easy.
Well, not quite that easy. Remeber, that little rubber fuel hose is under 40+lbs of fuel pressure. He'd have to have one made up somewhere, like a place that specialized in hydraulic fittings (either rubber or braided) with the proper ends so that it wouldn't leak or blow out when the pressure was on.
All depends on the type of cam and what the car is being used for. You'll get a hundred different responses as to what type of cam to use, but rather than just give my opinion (which is a conservative dual grind FWIW), I'll set you up with a CompCams link that will send you in the right direction.
http://www.compcams.com/Technical/CamSelection/
Off the top of my head though, with a decent set of heads (ported or otherwise) and intake, you could be looking at anywhere from 10-20hp with the properly selected grind.
Well, if I am not mistaken, you can use the rails off of a 5.8L truck. JUNK YARD. As far as I am conserned, I'd run fuel injection if my car was originally injected, but a carb set-up is easy, cheaper, and delivers just the same performance. You just gotta know how to set your carb up. If your not racing a points game, just street cruisin and doing some weekend track times, get a carb w/a choke, have someone set it up for you, and it will please you. We had carbs for a lotta years. They work. Its gonna be a Demon for me.
I prefer a roller shaft, but they are exspensive. If ya wanna see how that flat tappet is gonna do, look up at HLLON4wheels's ride. He's got one and his car ROCKS!
