Hi Tuners,
I'm pulling my hair out, and I don't have much left! I am setting timing use base table, altitude and MBT table set to 55, all adders and retards zeroed out. Global adder=0, multiplier=1, load switch 0. I researched Gradys website, reviewed his tune, compared to mine and I can't find the problem. The problem is that I am datalogging timing higher than any tables. Sometimes, it looks like the timing matches, sometimes not. It can be as high as 6 degrees more than called for in the base table.
As far as I understand, using the loadx and rpm, I should see my table timing match the datalogged value. I'm using 1.30(7) I'm using the J4J1 tune as a base.
Looking for ideas here.
thanks Eric
thanks Eric
