CD player!
  • Thread starter Thread starter ryan218
  • Start date Start date Jan 3, 2008
  • 3
  • 4
  • 5
First Prev 3 of 5 Next Last
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Jan 4, 2008
#41
  • Jan 4, 2008
  • #41
glowstang93 said:
Ryan, first let me say I wish you all the luck possible in getting your cd player working. I pulled up crutchfields' site, put in 88 mustang convertible with 6 speakers and got this link, hope it helps you. It shows 3 plug ins for premium sound.
http://www.crutchfield.com/S-2GQ4HqJH8Sg/App/Product/Item/Main.aspx?I=120705006
Click on the Read More part of the item description. It goes into detail. Here is what it says:
Crutchfield custom wiring harnesses are lifesavers! You'll save many steps when installing an aftermarket receiver in your car. Simply splice the color-coded wires on your Crutchfield harness to the wires from your aftermarket radio — and do it in the comfort of your home without having to struggle with splicing wires behind your dash. (Most of the wire splices can be made on your work bench or kitchen table. Soldering is best, crimping is also very popular — see "Accessories").
Next, plug the Crutchfield harness into the harness that you removed from your factory radio.
Read More
Since you didn't have to cut off your car's original radio connector, it's easier to put the factory radio back in when you sell your vehicle or return it at the end of the lease. Just plug the factory radio back in and keep the aftermarket radio! Best of all, the harness is free with most of the receivers Crutchfield offers! 30-day warranty.
Connections:
Note: Two speaker harnesses are included — one is used if you have a factory amplifier, one is used if you don't. If there is no ground wire in the factory harness, you'll need to make a ground connection between your new receiver and your car's metal chassis.
12V constant power
12V switched power
chassis ground
power antenna turn-on
dimmer
left front speaker +/-
right front speaker +/-
left rear speaker +/-
right rear speaker +/-
i didnt get that small connecter there! it says preinum sound on the bag to!!
my mustang only has 4 factory speakers? two in the dash in 2 in the rear it dont have them in the door!
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#42
  • Jan 4, 2008
  • #42
The 3 pc harness from crutchfield shows a small plug. That plug applies to the 93 that has the blue data cable like mine had.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Jan 4, 2008
#43
  • Jan 4, 2008
  • #43
Solder those wires together or at the very least use butt connectors.
ryan218
Dec 28, 2005
columbus ohio
Jan 4, 2008
#44
  • Jan 4, 2008
  • #44
5.0Droptop said:
Can I use your chap stick? Goshhhhhhhhhh
get your own!
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#45
  • Jan 4, 2008
  • #45
93 premium sound has the blue cable with square plug.View attachment 338729
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#46
  • Jan 4, 2008
  • #46
ryan218 said:
get your own!
friggin idiot!!
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jan 4, 2008
#47
  • Jan 4, 2008
  • #47
Also, if you go to crutchfield.com, there is a link on the left hand side that will even give you a pdf of the instructions of how to wire the adapters up. Just plug in your year and make, model.. Then go to the link to the right that says what is included in installation. Then from those parts, you can get to the pdf of the instructions. Should help some, I hope.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#48
  • Jan 4, 2008
  • #48
You cant help STUPID......
ryan218
Dec 28, 2005
columbus ohio
Jan 4, 2008
#49
  • Jan 4, 2008
  • #49
ok my factory harness in my car is not for a preinum sound and has no amp, this is why it only has 8 wires on the spkr plug and there is no wire for the amp on the factory side of the power plug.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#50
  • Jan 4, 2008
  • #50
Hey Ryan. Have you followed the speaker harness all the way back as far as it wil go? Feeling for any other plugs?
Honestly though If the oem radio works my guess is some thing is wrong with the radio or the install plugs.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Jan 4, 2008
#51
  • Jan 4, 2008
  • #51
The funny thing is My 93 had premium sound and it only has 8 wires also.
I think the 6 speaker set up has 2 speakers wired in series somewhere else down the line. The amp harness had only 8 wires also..
ryan218
Dec 28, 2005
columbus ohio
Jan 4, 2008
#52
  • Jan 4, 2008
  • #52
yes and yes and the radio is a new second one...plugs maybe
ryan218
Dec 28, 2005
columbus ohio
Jan 4, 2008
#53
  • Jan 4, 2008
  • #53
this is retarted i hate wiring!!!!!!!!!!!!!!
87_stang
131
Tonganoxie, KS
Jan 5, 2008
#54
  • Jan 5, 2008
  • #54
Are you using a test light? Did you bump 2 wires together by accident? I have had that exact same thing happen to me before. I personally think you are wiring it wrong (could be new wires spliced into the car and different colors) and are frying your stereos.
stykthyn
5,232
2,652
223
gainesville
Jan 5, 2008
#55
  • Jan 5, 2008
  • #55
this whole thread is funny...keep it going.
nvr2low
syracuse ny
Jan 5, 2008
#56
  • Jan 5, 2008
  • #56
i think you are hung up on this amp thing and its not the issue. if the f150 unit that was in there was working on 2 plugs then he only needs those two for this deck to work. ford has had some funky odd ball connectors, ive done tons of them and have had to go back for a new harness quite a few times. have you been pulling on the wires at all? done anything with the speakers? im wondering if one of the speaker wires has worn through causing a short on a pice of metal in the car. that would put it in a protect mode asap i would think.
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Jan 5, 2008
#57
  • Jan 5, 2008
  • #57
I think you are wiring terribly Go get a solder gun at walmart for 5 bucks and some solder and maybe you can get some good connections. My 12 yr old sister knows no to just twist them together!
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Jan 5, 2008
#58
  • Jan 5, 2008
  • #58
Not trying to be critical, but they're right, Ryan. Give up the twisty-tie method and invest in some wire nuts, crimp connectors, and/or a soldering gun. You're going to have more headaches with loose connections by twisting n' taping your wires than you already are with trying to resolve this whole issue.
The Best Buy wiring harnesses and radio brackets I've seen available are generally crap, IMO. I've actually had better luck with that other brand of brackets/harnesses available for sale through Wal-Mart. Go stop by there sometime and look at THEIR harnesses for Ford Premium Sound and you'll see the extra plug we're referring to, which I STILL say is the case with your car - you have the amp bracket right there, dude, so you obviously had an amp attached to it at some point and, thus, had the premium sound package. IIRC, they cost around $9.
Your only other alternative, if you insist on refusing to use the stock harnesses, is to run all-new wiring to all of your speakers and power sources ... which is WAY more of a PITA than just figuring out how to use the stock harnesses. Again, bear in mind that you will need more than just a power and ground wire, as you need a constant battery supply wire (non-switchable source) to keep your radio presets and audio settings and whatnot on your CD player.
ryan218
Dec 28, 2005
columbus ohio
Jan 5, 2008
#59
  • Jan 5, 2008
  • #59
stfu
im not sodering them or crimping them down untill i figure out why the hell it aint working.
ryan218
Dec 28, 2005
columbus ohio
Jan 5, 2008
#60
  • Jan 5, 2008
  • #60
even if i go get one i have NONTHING to plug that 3rd one into!!!!
  • 3
  • 4
  • 5
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
