  • 1994 - 1995 Specific Tech
CEL on!!!
  • Thread starter Thread starter Guero
  • Start date Start date May 6, 2006
Guero
2,148
May 6, 2006
  • May 6, 2006
Ok here are the codes on the reader-
1.122 tps to low. its at .98 so it can just be in the memory.
2.212-loss of ignition diagnostic moniter signal/SPOUT circuit grounded( i always had this dam code but never a cel light)
3.332 insufficientegr flow detected (ist time ever came up)
4.556 fuel pump relay primary circuit failur
which will cuz the light to stay on constently?
Zero Signal
2,633
Tucson, AZ
May 6, 2006
  • May 6, 2006
I get mine all the time for the EGR since the vacuum line to it busted. Unplug the battery for a couple minutes before driving it again to see which codes come back and which don't. The fuel pump one is the one that would worry me.
mytight95
2,605
Dothan,Al
May 6, 2006
  • May 6, 2006
yeah i would look at the fuel pump, filter etc.. Do you have a gauge to check for bleedoff, etc.
jason
Guero
2,148
May 6, 2006
  • May 6, 2006
gauge for what???? the fuel pump one is the one in the overflow tank?
mytight95
2,605
Dothan,Al
May 6, 2006
  • May 6, 2006
i was thinking that it could be getting too hot(wiring) due to a bad pump trying to compensate for weak internals. I was talking about a FP gauge on the rail.
jason
Guero
2,148
May 6, 2006
  • May 6, 2006
i have a bad pump thats right never crossed my mind, well at least i think i do, and i have a gauge on the fuel rail
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 6, 2006
  • May 6, 2006
did you delete your EGR doing H/C/I ? when/if you get a custom chip made be sure to have that turned off
Guero
2,148
May 6, 2006
  • May 6, 2006
egr is on.
Guero
2,148
May 6, 2006
  • May 6, 2006
i looked closely and one of the egr lines were broken, taped it see if the helps it should
HISSIN50
34
129
May 7, 2006
#10
  • May 7, 2006
  • #10
The fuel pump code is often a ghost code - not to say that it isnt anything but it might be nothing. It can mean there is an issue, or that for a split second the fuel pump lost power for some reason.
John's right about the EGR - check the line for a break (I broke mine right where it bends at the top of the EGR). This should not give you a constant CEL though. EDIT: you found a bad line already.
I also would clear them, drive it once and note the codes. If the CEL hasnt come on, once it does come back on, pull the codes again and see which one is new.
Good luck.
Guero
2,148
May 7, 2006
#11
  • May 7, 2006
  • #11
it hasn;t came on,, dam hissin were do you get all the info from. wish i knew what you know. and i did check for breaks, found one under the cai. so i taped it and put it back on
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 7, 2006
#12
  • May 7, 2006
  • #12
Yea, somewhere in that big plug. If you find out whioch wire it is, let me know. Im having the same problem.
Guero
2,148
May 7, 2006
#13
  • May 7, 2006
  • #13
i think you have to replace the whole thing
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Runs really rough - Code 212
  • BrightVa
  • Sep 1, 2023
  • 2 3
5K
1994 - 1995 Specific Tech Jun 12, 2024
BrightVa
