Centerline Telstar skinny wheels installed
missouri_guy197
1,441
St. Louis, MO
Wow, they look good...and they don't stick out as far as I thought they would...I think I may have to spring for the rears soon because these rims are sweet looking...
And for the tech part:
I used H&R 30mm spacers and they pretty much bolted right up...The only thing I had to do is cut off about 1/2" from the tips of my stock lug studs since they stuck through the front of the spacer...Other than that, no grinding needed whatsoever and I can still used my stock lug nuts with these wheels since they take the acorn style conical taper nugs...
hi i got a 1989 turbo mustang with the sn95 front wheel up grade, need to know if the telstar 15x7" wheels fit ok, car came with skinnies and bars on calibers are cut off, afarid to buy and not fit, need 5.00 back space which will allow small spacer if needed, center line says they wont fit and no ship back on custom made.
thanks steve
