Changed engine configuration - reload base map?
darryl paarman
212
93
39
ft bragg nc
I need some advice- My concern is that I do not want my new engine running rich and damaging it .
WAS - Vortech ,60lb injectors -speed density, GT40P heads,GT40 intake- no maf - not using AFR guage. Ran rich all the time.
New - TFS top end kit, brand new rebuilt engine -24 lb injectors, MAF
Would it be better to find a base map tune and go from there - rather than try to figure out and find all the items the Previous owner changed.?
Either way. you're starting almost from scratch. TS allows you to store multiple projects. It could be that the OLD has a good startup tune where the NEW might not.
BTW, you can keep the MAF & use it in conjunction with the onboard MAP sensor.
Upload your current tune. Give it another name instead of Current Tune.
the maf is a ford part # F1ZF 12B579-AA AFH55-03B 3J07. off of a Cobra Mustang
From the '93 Cobra?
Calibration curve is available for these. If I don't have it, Steve might.
I think it's a 60 or 65mm housing instead of the 55mm
Also, what are the 24 lb injectors? Also from the '93 Cobra?
I don't have the curves for that one.
Given that your new configuration is so different from the old configuration, I'd start from scratch with the tune that came with the MSPNP2. Your current firmware is 3.3.1, upgrade to 3.4.2 before proceeding further.
1986-1993 Fox Body Mustang 5.0, 1986-1988 Thunderbird 5.0 base map
MS2E v3.3.1a MSPNP2-EEC4A8
Reactions: darryl paarman
