Changed the brakes.. no pedal pressure.
could you go over on how to bleed the brakes please.
as far as the sequence goes:
RR = right rear first
LR = left rear
RF = right (passenger side)
LF = Left front (driver side) last
you will need a friend to help you so he can pump the pedal till it gets hard to push down ussually about 3-7 pumps. Then you open the bleeder screw at the caliper you are at and let the fluid go out once you see very little pressure close the screw and repeat on all other calipers
