  • 1994 - 1995 Specific Tech
changing valve stem without a tire machine
  • Thread starter Thread starter stprorolla49
  • Start date Start date Mar 29, 2007
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Mar 29, 2007
  • Mar 29, 2007
is there any way to change a valve stem without using a tire machine? im trying to find some way to do it in my dorm room because i dont have a ride to firestone and they close at 6, and i have class from 5-7:30
Aryan15
236
CA
Mar 29, 2007
  • Mar 29, 2007
You can pull it with that special tool. Must be deflated first.
Bosko5.0
1,067
longwood, FL
Mar 29, 2007
  • Mar 29, 2007
or you could drill a 3 in hole in the tire and get it in that way unless you want to keep your tires.
to install you have to deflate tire push the tire in place stem in secure it try prying tire back onto rim inflate and done
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 29, 2007
  • Mar 29, 2007
You can very carefully (don't wanna screw up your brakes or wheel) lower the car down on a jack, using the brake rotor to break the bead on the tire, and pop the new one in that way. Some pliers are all you need to pull the old stem out. Same goes for popping a new one in.
stprorolla49
1,455
15
39
Mar 29, 2007
  • Mar 29, 2007
thanks guys its all good, it was kinda a stupid question...i took the tire/rim off and had firestone change it for me...thanks
go-stang5.0
2,244
Glenview,Il
Mar 29, 2007
  • Mar 29, 2007
Wow stangGT1995...sounds like you have done this before....But if you have one of those floor jacks that hit the floor as soon you turn the release valve...you could end up in a messy situation.
BlownFiveLiter
18
108
Chicagoland
Mar 30, 2007
  • Mar 30, 2007
Yeah, I can be a MacGuyver of sorts when trying to make things work without the correct (expensive) tools...
BlownFiveLiter
18
108
Chicagoland
Mar 30, 2007
  • Mar 30, 2007
Oh, and I did work at a Firestone nearly 10 years ago doing general service (tires, oil, brakes, minor other items), so I knew what had to be done to break the bead to swap the valve stem.
stprorolla49
1,455
15
39
Mar 30, 2007
  • Mar 30, 2007
haha yea i used to work at firestone also, and i decided it was a terrible idea to work there any more...it was way to tiring and i felt like someones grease bitch...forget that, theres a difference between wrenching on your own car, and wrenching on someone elses
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Tire size question 1986 gt hatchback
  • B0udreaux
  • Jan 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 17, 2026
B0udreaux
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
