Throttle Position Sensor adjustment is a very basic but often asked question. The benefits of resetting the TPS is as follows:
1. Increased throttle response
2. Smoother idle (when you are lean at idle)
3. Can be used to compensate for a rich or lean idle
4. EEC will reach wide open throttle operation sooner resulting in faster acceleration
stang&2Birds said:BTW: That's PURE AND TOTAL BS!!!!!!!!
NONE, I repeat, NONE OF THAT IS EVEN CLOSE TO BEING TRUE!
Here is MY TPS tech article:
http://www.veryuseful.com/mustang/tech/engine/Mustang-TPS-FAQ.html
BTW: I taught this stuff and do this type of stuff for a living!
I've also read the EEC assembler code and the Ford Documents.
GUFB is "only" 591 pages. The newer strategies are over 1000 pages.vristang said:have read parts of the GUFB doc, but not all 1,700 pages.
Nope. For the A(L, and most Fox stangs, WOT is 2.7v above the startup voltage of the TPS. I'm pretty sure that was even invristang said:I thought the the comments on triggering of WOT made sense, though I see the affect as being minimal.
Can't.vristang said:I hope this doesn't turn into a pissing contest, because I am curious to hear how a good debate will go on this subject.
stang&2Birds said:GUFB is "only" 591 pages. The newer strategies are over 1000 pages.
ELECTRONIC FUEL INJECTION (SFI-MA) STRATEGY BOOK
STRATEGY LEVEL "GUFB"
NOTE: OVER 16K; REQUIRES 2732 CHIPS
FOR USE WITH EEC-IV MODULES: SFI-MA1, SFI-MA2 AND SFI-MA3
is 591 pages in PDF form.
TECHNICAL NOTES ON THE EEC-IV MCU
Compiled by Tom Cloud
I think that parameter was also in Mike Wesley's orig EEC "custom chip" software. "Somewhere" I have his orig software that he made public.
Can't.It's WELL know on the tweecer/EEC-tuner/ect boards. Plus, it's in GUFB spec and the EEC assembler code. If someone else has also written code for the EEC (I'm not talking about using a Tweecer), then I'll talk to them.
Otherwise, they can read MY article and "talk to the hand" if they disagree.
stang&2Birds said:From:
From Chapter 19-43:
INPUT CONVERSIONS AND FILTERS - GUA0
PEDD-PTOPE, FoMoCo, PROPRIETARY & CONFIDENTIAL
THROTTLE POSITION RATCHET (RATCH)
The throttle position ratchet (RATCH) continuously seeks a lower value for
both throttle angle breakpoints, CLOSED THROTTLE/PART THROTTLE and PART
THROTTLE/WOT, by seeking the lowest filtered throttle angle (TPBAR). The
algorithm is not used during CRANK mode.
CRKFLG = 0 -----------------|
| | RATCH = TPBAR
TPBAR <OR= RATCH -----------|AND -----|
| | --- ELSE ---
N > 450 RPM ----------------| |
| NO CHANGE TO RATCH
It should be on the "yahoo" site.vristang said:ICould you post a link to the article you mention, and the Tom Cloud doc?
vristang said:I was under the assumption that the base tps was taken just after start-up, and did not change while the engine was running.
According to the GUFB, RATCH is trying to reset constantly when ever the engine is running?
HISSIN50 said:I don't pretend to know that much about the TPS (I don't want to) but I thought it did continuously check for baseline values (otherwise cranking while at WOT could create some issues, for instance).
[on soapbox]HISSIN50 said:I don't mean to come off confrontational (this is a much friendlier, respectful forum IMHO than some of the others), but if idle surging wasn't programmed by design, and some folks swear by farting around with the static TPS reading (it's free, so why not), what's the harm?
The tweecer is nice for datalogging because of the support for the log files.vristang said:Those I have spoken to using PCMX still use the tweecer, but only for datalogging.
