Borrowed a cheap scanner, pulled this code - ECT sensor. Went to the local autozone 5 minutes from my house and picked one up. Rplaced the sensor, cleared the code. I started the car and within 10 seconds the code SES light was back on.
Background on the car...
belongs to a good friend of mine. It was basically stock - x-pipe, flowmasters, BBK CAI. He overheated it bad and destroyed the engine. It sat about a year until I brought it over hear and began the rebuild.
Specs are:
91' 302 HO .040" over
GT40 heads mildly ported and o-ringed
Cobra 1.7 rockers
Cam is some mystery cam he brought me, it's .560" lift with the 1.7 rockers,
I measured it and did the math. PTV clearance is .175 E, .145 I
Cobra intake and 65mm TB
BBK 76mm MAF
30# injectors
BBK 255lph pump
BBK adj. FPR - set at 38psi
180* stat
BBK shorties, Summit x-pipe, 2 chambers w/ dumps
MSD billet distributor & blaster coil - timing 14*
The symptoms are - if I floor it, it breaks up bad and spits black smoke like diesel.
Should I try a BW sensor from Advanced? I read several reviews online that say they had problems with the AZ sensors. I am hoping it's not a problem with the wiring harness.
Any help would be greatly appreciated. I want to get this thing fixed so he can enjoy his car again. The Power Tour starts in a week, he has dreams of taking this car on the first few stops. I didn't make any promises, but am trying my best to oblige.
Specs are:
Cobra 1.7 rockers
BBK 76mm MAF
30# injectors
BBK 255lph pump
180* stat
