Considering lots of Nitrous, what do you suggest?
  • Thread starter Thread starter streetstang67
  • Start date Start date May 17, 2005
First Prev 2 of 2
txwoody
99
4 hours to anywhere, TX
May 18, 2005
#21
  • May 18, 2005
  • #21
That under manifold system that would be cool. I dont think that I will ever use NOS, but I do the way some of them are plumed. Like pearlorange's set up I think the pluming just looks sharp.
10secgoal
2,801
San Diego
May 18, 2005
#22
  • May 18, 2005
  • #22
One myth to put aside is Nitrous does not kill motors. Hp shortens the life of a motor. Whether it be turbo, nitrous, or wild compression and a wicked cam. HP puts added stress on parts regardless of the method you use to make it. An ill tune will kill any motor, including an N/A application. Blaming the death of the motor on the bottle is like blaming a murder on a gun.Nitrous makes HP, if your parts can't handle it, don't play with it. There is a limit for each part in your motor. If it is stock, you can run more nitrous until you reach its limits. If you have heads, cam, stroker, you are at the block limits right there. Add 150 hp of nitrous, split the block and blame it on the nitrous. Run 50-100 shot, premium fuel, and follow the directions EXACTLY and you'll be fine. I would be more afraid to run 100 shot on a stroker than a stock motor.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
May 18, 2005
#23
  • May 18, 2005
  • #23
I couldn't agree with you more 10secgoal.
streetstang67
573
Lexington, SC
May 18, 2005
#24
  • May 18, 2005
  • #24
Those hidden kits are cool, but expensive. Is there a cheaper way to have it all hidden, just with a normal sniper kit or mabye the top shot if thats any good?
A67StangMaster
401
San Jose CA
May 18, 2005
#25
  • May 18, 2005
  • #25
Nitrous is good but only if your parts could handle it. Parts that could not take the presure and heat will fail. I would say get forged pistons or just new piston rings and some good spark plugs change the radator fluid and something that will cool the engine fast and stay cold because when Nitrous is added into the engine it heats up fast. ohh yea and give it short bursts dont go crazy with it.
10secgoal
2,801
San Diego
May 18, 2005
#26
  • May 18, 2005
  • #26
I have been known to spurt out nuggets of truth everyonce and a while.
First Prev 2 of 2
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
