Converting to Roller Cam
ThePrimerSuspct
i picked up a 93 lightning motor for a decent price, but i want to freshen it up before i drop it in. everyone says to use the stock 5.0 H.O. cam when converting it to a roller, but since everyone upgrades from the stock cam, and the specs arent that far off i dont really see the point. i was trying to decide what cam to go with. its going to be otherwise stock (for the most part). i was thinking an e303 or a b303. i think i like the b cam the more i think about it. any input?
Depends what vehicle this is going in. They are saying this because the Ford trucks are Speed Density and the 5.0HO cam is the best cam with no issues. Otherwise if you are putting the engine into a mass-air mustang, you can go with any cam you choose.
Kinda need to know the ultimate combo to recommend a cam. The e303 is a decent cam, but the b303 is more of a top end power sort of cam. If you are putting this in a truck or an AOD, i wouldn't recommend it.
The stock HO came, especially 85-88, is not that bad really. A decent set of 1.7 RR's on a HO cam can still get you tons of power with great drivability
well thats kind of what im looking for here. ive been asking around lightning forums and all they keep telling me is stock 302 roller. but thats because they are running them in trucks. i havent really been able to find anyone whos done the same thing im doing. so i figure ill just ask the 5.0 gurus seeing as how the engines are basically the same. i had the car running a stock 302 SD setup out of a LSC with a t5 swap for 4 years with just basic bolt ons (headers, exhaust, UD pulleys) and i was pretty happy with that. it was a lot faster than my 95 GT. but i wanted some more power, and ultimately just to do something different, which is why i started with a cougar instead of a mustang in the first place.
The engines are not the same. Your 351 is considerably bigger than a 302. The GT40s are still a pretty small head for the 351w. Having said that, I'd have to reccomend the stock 5.0HO cam right now and switch cams at some point down the road if/when you go to aluminum heads. The displacement of the 351 will work much better with the torque curve of the 5.0HO cam and the heads are too small to take advantage of higher lift, or a powerband shifted higher than 1000-4500 RPM
perfect answer. that pretty much exactly what i needed. someone to explain why. thank you.
