Coolant Overflow Discharge
JD1964
there is enough sticking out to grab on to
3,640
1,660
194
Maryland
Obviously the goal is to contain the coolant in the system where it belongs. But as many of us know, sometimes it pukes out the overflow tank in the engine bay and can be really dangerous when it gets on the tires.
I was thinking of getting a long piece of fuel hose and running the overflow discharge to the area by the rear bumper. This way if a discharge happens, it's not dousing my tires. I figure it's gonna hit the street either way. Better behind my tire than in front of them.
Any body done anything like this?
john, why is your car puking out coolant. that isnt normal. I suspect it is because of your leak in the radiator and that you removed the gasket on the cap. In your case, I would run a hose from the bottom of the overflow for the sxcess coolant and loop it back into the other hose with a T, so it doesn't end up draining out your radiator. This way it will just act as a way to recycle the coolant back like a recovery tank. That or get a bigger overflow that can contain the expanded amount of coolant capacity.
You're right mike, I'm slappin a 16lb cap back on there and see how it goes. BTW, the overflow tank that comes with my aftermarket radiator is way lower capacity than the stock one. Maybe I'll add a secondary one for extra capacity.
