  • 1994 - 1995 Specific Tech
Cooling issues!!
  • Thread starter Thread starter LandonC
  • Start date Start date Nov 8, 2004
L
LandonC
15
  • Nov 8, 2004
I know you will all laugh, but which way does the thermostat go in a 94' GT? Just for piece of mind! I recently did a fox intake conversion(everyone should), and I put a 180 degree thermostat in. It takes forever to warm up, the gauge fluctuates to almost the red line, then it'll cool off for a while. I don't know if the stat is sticking, the water pump is going bad, or if there is air in the system. My fan seems to not run very long, could the stat make it do that??? It's on for 5 to 10 seconds. The pump isn't making much, if any, noise. It's hard to tell w/ cause my idler pulley is a little noisy, but it always has been. please help, I'm pulling my hair out and I need all I have left!!
M
mackey
1,284
Beverly, Massachusetts
Nov 8, 2004
  • Nov 8, 2004
You have alot of air in the system. You should let the car run with the radiator cover open and keep the car at about 2500 rpms.
95Cobra302
394
Daytona Beach, FL
Nov 8, 2004
  • Nov 8, 2004
Make sure your stock gauge or sending unit isn't bad.
ProKiller
3,064
15
78
PA
Nov 8, 2004
  • Nov 8, 2004
did you drill two little holes in the T-stat? this helps alot with air in the system.
M
mackey
1,284
Nov 8, 2004
  • Nov 8, 2004
I wouldn't drill holes. I have the 180* therm and got the air out by just running it...
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
