I just finished tearing off the cowl cover and the cowl panel also. Luckily just some pin holes around the hats. It will all get blasted and epoxy primed before reinstalling. Is it crucial that the seam sealer goes in between like the factory, or will a coat on the outside seams work? I know my mig welder will not like that stuff. Also, I am losing sleep thinking about the carnage left after the spot welds burn the primer off inside the seams
(shudder). Is there a solution or am I just being the usual paranoid perfectionist? I will try the "hat" repair since the metal isn't eat up. What about the studs that hold the fresh air vents to the cowls under the dash? Will they come off with the hats?
