Datalogging ??? issue
blksn955.o
3,263
st.louis mo 314
Got the first round of logs to check things and it was just a quickie selection of things. Then dumped that log into EA and got the MAF changes. Ran around with those changes and things feel good.
I went to log this past weekend both Sat and Sun. I logged "actuall load" Sat as I could not get any other EA tabs to calc. saying I had selected an improper item to log. I was aiming to get "load X".
Got back and the load X was empty and the reg. load was populated :mad: . Sun I logged %load hoping to get load X. Nope it again populated the reg. load in EA...:mad: :mad: .
I lost my list of items to log I had been going by and cannot find were I got them. Do I need to log both load% and actual load? to get the load X to populate? It is the only thing keeping the calcs from working and I mainly want to get the inj. timing setup.
Thanks for reading a rambling/long post...
As far as i have tested you can log one or another or both, did you write the whole tweecer after setting the payload?
Use the EA Table of needed values to get that one
Yes wrote the tweecer the same way I always have. This is a new problem I have past datalogs that are fine as far as what is selected/needed.
I have logged both one at a time but each one only populates the load and not loadX. Actual load only populated the load, and load % only populated the load neither populated the loadX.
I know I need loadX but getting it to log in the correct col. is the issue. Do I have to log both to get the loadX to populate?
thanks for the reply.
