Desktop Dyno
MattK67
32
I have pretty much finished building the motor for my 67 stang and I am curious as to how much horsepower its going to make. I won't be installing it for a while so I can't take it to the dyno anytime soon. 60 over bore with edlebrock performance cam, intake, 600 cfm carb, rebuild 76 heads. Anyone have a ballpark number?
gotta give alot more info than that. what lift, duration, lobe centers, valve timing, compression ratio, what size headers are you going to run, what intake, what lifters, what valve sizes, what bore and stroke? answer these questions and then you can get some good answers.
My engine build desktop dyno numbers were only 5 horsepower different from the actual rear wheel horse. As mentioned above, be precise as you can, and it will turn out pretty darn close.
