Did I overdo it with my injectors?
GRGT1994
1,034
I got 30 lb injectors with my buildup this summer. Looking at my mods in the sig, did I overdo it, or are these about right?
At some point, I plan to get a dyno tune or tweecer it.
If I did overdo it, any opinions on how much further I can push it on these injectors (stroker/NOS/supercharger/etc).
30's is a bit too much injector for a 302 with h/c/i (unless you got a high spinner). You will most likely experience a rich idle/surging idle/and hot start issues due to too much cranking fuel upon start-up. You will have a "fatter" a/f ratio as well. I have seen a couple cases where they swapped back to 24lb injectors and gained a minimum gain at the track. Only change. Seen it more than once. Truth to it? I don't know...but it makes sense. A bit leaner overall is a bit more power.
A tune or tuning device will solve or atleast help you...but won't help your wallet.
Good Luck!
