Diff Fluid...
2007_Crown_Vic
133
26
48
Hi, I was searching some posts here and there seems to be mixed opinions about diff fluid types and friction modifier. It seems a lot of people say synthetic fluid doesn't, or at least shouldn't need friction modifier. They say to run it and if there is chatter add a bit.
I was planning to use Pennzoil Full Synthetic. Anyone else used this? How did it work for you? Thanks!
I've run the Mobil 1 limited slip diff oil in my car for almost 20 years now. Been changed a few times. No chatter, no issues and my car still 2-wheel peels with the orginal, never rebuilt clutches.
I've never added additional friction modifier.
Reactions: 1 user
Thanks. On Pennzoils website they say this has sufficient friction modifier already in it for most applications, and that only newer high horsepower cars may need more. I guess I will use it and just see if it chatters at all. Being a bone stock 1990 GT I think it should be fine...
In the past, folks have always said to try it as is, and then add friction modifier if needed. I think i've done 3 drail/refills with the Mobil and never needed to add it.
Reactions: 1 user
I use the Mobil 1 and modifier but I have the F150 “Z” spring so it puts a bit more pressure on the clutches and the modifier was recommended by others that have this setup.
Run it without as it’s easy to add.
