Difference in C/C Plate years?
Adams91LX
689
12
29
Plano, TX
I have an 80 ghia that has been 5 lug swapped, 5.0 swapped, the front suspension is all from a donor 91..
question is, is body the deciding factor to which years c/c plates? or is it the struts that decided the year?
this may be a stupid question... i just dont want to order the wrong ones...
also do the lrs strut tower brace's work with mm plates?
thanks
-adam
fivespeedsteed
747
18
69
Richmond, VA
the holes are different sizes. the 87-89s with cc plates the holes are big enough for you to get it like 6 degrees of negative caster, my 90-93 though with cc plates the holes only allow me up to about 4.5 degrees. the holes for the caster adjustment are different sizes. if you did 87-89s youd have to grind out more of the hole for shock adjustment
