Do I need Cam Gear Kit.
04YELLOWGT
1,135
Indiana
I decided to hold off on the 31 Splin Axel and dif. and put VT Stage 2 Blower Cams in since the engine is going to be out. So Im getting the cams and springs but do I need the Cam Gear Kit also? It says you need them if you have pressed on cam gears. Do I have pressed on cam gears?
Also how much extra power will I see with these with stock heads?
Thanks :SNSign:
