do i need limited slip frition modifier?
5.0Torx
252
hey all, a while back i did 5 lug to my 93 LX in my sig. i bought royal purple rear diff stuff and it said on the bottle that it has friction modifier in it already. I also bought a tube of friction modifier but didnt use it, figuring i could use it later if i wanted to. well, after driving it around for a bit, it seems to peel out easier than before.
should i add the F.M. or not?
haha nope. my truck and my bro's lincoln mk viii have open diffs so i know what it feels like, and my 5.0 feels more like those than it did before. before it was pretty good, i felt, for 113k miles. possibly it was rebuilt by the PO so its still fresh.
Regardless, can you get a LSD thats too stiff? should i add only some of the FM to augment whats already in the royal purple, or should i just put it all in and not worry about it?
thanks for the reply
Typically, the friction modified is used to make the diff more slick so you can make turns. If you cut the wheel and try to do circles and you notice the inside tire scuffing or chirping then it's time to add the modifier.
If you can turn nicely with no noise or grabbing, then you don't need the modifier unless you want to make the diff a little looser. There are trade-off. More grab usually means more wear. Up to you what you want.
Nope. It's the opposite.
If you want it more grabby, use fluid that doesn't contain any limited slip additive. Then add a little until you get to the point you like.
The FM bonds to the clutch disks and makes them slip more...so the more you add, the more slippage you get between the plates and the easier to turn.
I say use the fm if you have a new or rebuilt unit, but if its old and slinging one tire dont use any and you may be able to get it to lock just a little bit longer, thats what I did before I rebuilt mine, mine used to spin one tire no matter what, I drained the fluid and added new fluid minus the fm and it locked 100 times better, I have since rebuilt mine. I still use no fm and it locks like a mofo:nice: It does chirp sometimes while backing up and turning though, but thats ok:shrug:
