Do these numbers seem right
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
mods are GT40 y303 heads , B cam , typhoon intake ,70mm TB and egr , 24 lb injectors , 73 C&L mass air calibrated for the 24s , stock shortys and stock gutted H pipe , 2.5 inch flowmaster catback
245 rwhp and 274 rwtq at 13.3 air fuel and 17 degrees initial timing 36 total.....
I was hoping a little higher , could the exhaust be holding it back that much ???????
ive seen 20+ rwhp gains with long tubes on other cars im wondering if mine will jump that much ? , also , would having no cats and a functional smog pump set up cause the air/fuel probe in the back to show a leaner reading than I got before with my wideband when I checked it in front of the cats ?
DMAN302 said:
Heads are OK, cam..well there are better...and as for your choice of exhaust...well...nough said. You have gotten correct numbers for the parts you've chosen.
:stupid:
Those heads with your combo are good to about 40 additional horses (vs stock) ...
Your cam will run to the end of those 24#rs so I won't worry about that :nice:
And your exhaust :rolleyes: (or as I've seen it spelled once "exost" ) ... come on 'dude', this just negates your whole post :notnice: :nice:
