Dogbone on rear end
310stanger
170
anyone on here remove theres, i removed mine being that it seems to me it serves no purpose at all. When I took it off it had to weigh a good 10 to 15 lbs. Am I gonna experience weird harmonics with 3.73s at highway speeds?
it is fro stock ratio gears.....after gear replacement it is much much less necessary.
there was a little write-up on how it is actually good to leave it.
i dont mind a little unsprung weight directly over my tires tho
any links to the write up on this part? im interested in the technical details and purpose of it. Ford obviously spent some money making it for a reason. Id like to know what its actual merits are.
The P/N for the Dogbone was the same no matter what gears came in your Stang. I say leave it on the car.
Exactly. Every gear ratio emits a different frequency. I also say leave it on but than again if you KNOW that it won't hurt anything, than take it off. I'm actually learning about this stuff right now in school so maybe ill crunch some numbers sometime and figure this out once in for all..
You DO NOT need it, it's 9 pounds with the bracket.
Took it off both my 89 LX's, didnt notice a difference, first one had 3.55's, second one had stock 2.73's, my 88 GT didnt have one when I got it. We took it off my friend's 96 GT years ago with the stock 3.27's, she didnt notice anything. Took it off my friend's 87 GT with 3.08's (swapped rear from 2.73 original) years ago, didnt notice anything, my friend took it off his 93 Notch, didnt notice anything, my friend took his off of his 97 GT with 3.55's, didnt notice anything.
Gear ratio has nothing to do with it, it dampens drive shaft harmonics, when the drive shaft reaches a certain speed it trys to bow in the middle. There was a write up about it somewhere, I think on one of the T-bird forums. Its weight over the axle, and not much at that, I think I'll keep it.
What exactly would be the idea behind wasting the time to take it off? No matter what it's there for, and whether it does its job or not, it certainly doesn't hurt to leave it on there. It's a little extra weight right where you want it.
MAC'n89Blckstng said:
Ford put it on there for a reason. Just because YOU think that it doesnt serve a purpose, there is an explanation for it. Just leave it.
Ford also put quad shocks on there and last i checked mine are serving NO purpose...lol. I think the dogbone was a bandaid for drivetrain vibration which by now since most of these cars are around 20 years old anyways, i doubht that it's going to dampen enough to make a difference.
Yeah... 9 lbs 20 years ago is a lot different than 9 lbs today. :lol:
Sorry man... I couldn't resist.
Yeah well, when you're talking about a unibody frame, crappy suspension and 20 years of driving and/or racing, then that 9lbs loses whatever effectiveness it had to begin with. :rolleyes:
BTW STFU :rlaugh:
im not gonna worry i have an aluminum driveshaft. most of the new fords dont have this thing on here. i think its jus a ford bandaid to satisfy whining complaining customers who cry about vibration. so far i notice no difference at all. thinks guys for the input though, i was jus hopin for actual technical input on it like if anyone actually heard of tests being done or what not.
Just because your car doesn't have wheel hop doesn't mean that A LOT of others dont have it either when they remove the quad shocks. Some people still get wheel hop with good aftermarket control arms, shocks, and springs, and the only fix is the quad shocks.
Yeah i didn't really mean that....that part about serving no purpose is that i've had them off, and the dampening action is completely shot.
Ford also put quad shocks on there and last i checked mine are serving NO purpose....
That's not true either. It's for dampening side to side horizontal movement. A lot of people say that once you do control arms you can ditch them, but some find that even then they get wheel-hop with the quads missing.
There are quite a few Mustang Myths
-Axle dampener
-Quad Shocks
-EGR coolant hoses
-ACT sensor mods
WHat else?
my car has quad shocks still and i still get wheel hop. the driver's side quadshock exploded and is pissing fluid everywhere. in my book: completely useless.
