  • 1994 - 1995 Specific Tech
Draw.....any one else.???????
  • Thread starter Thread starter drakesdad
  • Start date Start date May 26, 2006
drakesdad
961
Oregon OHIO
May 26, 2006
  • May 26, 2006
After the stall went in we took a few minutes to search for the draw that I have....Justin and I both have a significant one....I found that I have a 12 amp draw........we pulled the fuses and the problem child is the 50 amp headlight fuse on the driver's fender......we removed the fuse....draw goes down to .08....so I know that is my problem but I don't feel like searching endessly for a short......anyone else ever had this particular draw problem....from the headlights.......
Will
99FiveOh
2,051
20
99
J-Ville, FL
May 26, 2006
  • May 26, 2006
do you have anything running off the headlight circuit? And alarm system by chance? Try disconnecting your headlight switch with the fuse still in and see if the draw goes down.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
May 26, 2006
  • May 26, 2006
If someone could post a wiring diagram for the fuse block, we can isolate everything wired to that circuit. Then unplug one at a time until you find it.
Start with the headlights and fog lights first, since they are obviously wired to that circuit.
Scott
drakesdad
961
Oregon OHIO
May 26, 2006
  • May 26, 2006
When I bought the car it had a car start and remote.....the parking lights come on while it is running....I told my "mechanic" that helps try and teach me things that if it wasn't the amp, I would guess it would be the car start because it has had the draw since I bought it, before the HCI install.....
Will
99FiveOh
2,051
20
99
J-Ville, FL
May 26, 2006
  • May 26, 2006
does the car start device have it's own fuse? Where does it get it's power from?
drakesdad
961
Oregon OHIO
May 26, 2006
  • May 26, 2006
That's a damn good question because I don't know.....
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 26, 2006
  • May 26, 2006
I know this may suck ... but at least you found the problem by pulling the fuses, lol. I'm still having a time with mine.
Eventually, when I go pro like some of the others on here, I'll be doing some wire clean up and hiding while fixing up my engine bay. When I do that, all wiring that looks even remotely like it could cause a problem in the future .... it will be replaced.
drakesdad
961
Oregon OHIO
May 26, 2006
  • May 26, 2006
Yeah Justin, I thought about your problem today when I was searching for mine.....narrowed it down to what circuit.....only took a year ....
HISSIN50
34
129
May 27, 2006
  • May 27, 2006
If you feel like it, try pulling fuses 16, 15 and 1 (with your 50 amp fuse installed). See if the draw goes away when one of those three fuses are pulled. That would help narrow it down (along the lines of what Scott was saying).
Good luck.
drakesdad
961
Oregon OHIO
May 27, 2006
#10
  • May 27, 2006
  • #10
Thanks JT, I wrote those three down and will pull them and leave the 50 installed........but not this weekend.gonna play with the new stall...
Justin "Eventually, when I go pro like some of the others on here".....????????
What , you still in the minor leagues.........
I think I'm still in AA......
99FiveOh
2,051
20
99
J-Ville, FL
May 27, 2006
#11
  • May 27, 2006
  • #11
You sure like using that laughing smiley don't you!!??
drakesdad
961
Oregon OHIO
May 27, 2006
#12
  • May 27, 2006
  • #12
YEP
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 27, 2006
#13
  • May 27, 2006
  • #13
I'm in the Pee-Wee's, lol.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
4 amp draw from alternator regulator
  • Scottybronco
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
nickyb
D
Possible Parasitic Draw... Follow My Journey
  • daveinfl33777
  • Jan 11, 2025
  • SN95 V6 Mustang Tech
  • 2 3
4K
SN95 V6 Mustang Tech Apr 4, 2025
dennisc
D
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
