dunped codes got 11, 13, and 33!
Jaswir
578
Orlando, FL
Ok my cars been running really ****ty sence yesterday... sounds to me like its missing! dumped codes and i got 33
33
(O,M)
ALL - EGR did not open/ respond during test or if memory code, did not open intermittently - EVP EVR PFE
what does that mean???
Did you get the code while the engine was running or from the memory?
EGR - Exhast Gas Recirculation....DUring combustion, the engine creates high NOx levels, so some relatively cool exhaust gas is recirculated back into the intake, which helps reduce the combustion temperature and reduce emissions of NOx.
Whether you want to remove it or not is up to you. It will increase emissions. Personally, I don't see why you would, because EGR shuts off at WOT, so performace doesn't suffer. EGR also helps with fuel economy.
If you got that code, chances are your EGR valve is shot. Jrichker has a process of how to test the valve using a vaccuum pump. Search his posts, but chances are he'll chime in this as well.
33
(O,M)
Code 33 - Insufficient EGR flow detected.
Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal flickers. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1 ohm.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
EGR test procedure courtesy of cjones
to check the EGR valve:
bring the engine to normal temp.
connect a vacuum pump to the EGR Valve
apply 5in vacuum to the valve.
if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
if engine stumbled, connect vacuum gauge to the hose coming off of the EGR Valve
snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
did the vacuum gauge show about 5in vacuum?
if not, check for manifold vacuum at the EGR vacuum valve.
if you have manifold vacuum then connect vacuum gauge to the EGR valve side of the vacuum valve and snap throttle to 2500 RPM.
should read about 5in vacuum
The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators ( including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
Some basic theory to clarify how things work is in order…
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
Diagram courtesy of Tmoss & Stang&2birds.
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt.
Removing or diabling the EGR may cause the engine to ping at cruse RPM. Changes in initial timing or gas octane have no effect on this ping. The only thing that fixes it is a properly functioning EGR, Tweecer mod to the computer or custom burned chip for the computer.
ok while running i got 12, 44, 94
12
Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
44
AIR system inoperative - Air Injection
94
ok then my oil dip stick is loose! it came off the metal thing came off the heads so it was touching a spark plug wire and i could see it sparking! so maybe that was it! thanks for the help guys
ok just took it for a ride and now it runs great! It was the metal thing connected to the dip stick that was touching my plug wires and causing a steady spark! i could hear it and see it good because it getting a lil dark out! moved it away and tied it up took it for a ride and ran fine! so tomorrow just need to put it back under the vavle cover! thanks for the help but i think i got some things to fix so i am going to fix those other things to!
It sounds like you got it fixed. FWIW, a low lumpy idle or crappy WOT performance can be an EGR that is leaking (introducing gasses when it should not be).
i only get a crappy idle when i first start my car when the engine is cold... and after about 20 sec its fine... i have a great idle every time and runs strong and great! but i think im gonna replace it but there expensive for a new one so im gonna look on ebay!
Go back and re-read my post. The EGR valve itself may not be the problem. Inspect & troubleshoot BEFORE replacing any parts.
Jaswir said:
ok while running i got 12, 44, 94,
12 Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
44 AIR system inoperative - Air Injection
94 AIR system inoperative - Air Injection
Code 12 -Idle Air Bypass motor not controlling idle properly (generally idle too low) - IAB dirty or not working. Take it off and clean it thoroughly with throttle body cleaner. Clean the electrical contacts with non flammable brake parts cleaner at the same time.
Codes 94 & 44 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
JRichker is right on. The lack of cold-enrichment/IAC is where to look for an initial cold idle issue that clears up after some seconds.
I dont think I saw the second set of codes upon replying the first time.
Jaswir said:
your the man jrichker!
Yes he is. :hail2:
When I grow up, I wanna know 1/10th of what he does. Could I be like
: Jrichker
(In case that wasn't clear, it was a mini-me type reference).
