Was it an individual selling it? I can't find any on ebay. Would you care too help a stanger out if you see something I don't? ThanksRay@VSK said:It was a DynoJet & it was @ the tail pipe.
I seen somewhere I think a Pro-M affiliate site that was offering em for like $149.00 "$20 cheaper than Pro-M's site" I got mine new on ebay for $100![]()
autoXr1 said:Ray,
The reason I asked about whether it was a Dynojet or a Mustang is your air/fuel ratio readings may be different at the same RPM. A Dynojet will not load the engine like a Mustang. A Mustang produces measured results. A Dynojet calculated. A Mustang will create a more accurate and reproducable "real world" load that can mimic things like wind and rolling resistance...load will influence your fuel and timing curves...and air/fuel ratio. See where I am going with this? If you plan on adjusting your air/fuel ratio based upon this graph, you may be tuning based upon faulty data. So, you go ahead and tune based upon a Dynojet curve while the engine is under very little load, then get the car out on the road or on the track, in the real world and under real load, and your tuning is all off.
All that said, an intelligent, knowledgable, tuner knows this and will allow for some adjustment. So, sometimes a little over/undershooting on your fuel/timing tables in the right places under certain driving strategies on the Dynojet will land your tune just right when you are truly under load conditions.
The thing is, a shop can purchase 3 Dynojets for the price of one Mustang, so often money talks, and they hope they get some less-than-knowledgable customers that don't know the difference.
Your tune is only as good as the data you are basing it upon.
autoXr1 said:Ray,
tmoss said:So, your saying a dynojet does not load an engine much? I always thought dyno jets had a big inertia drum that loaded the engine through the chassis and I thought both measured torque and rpm from which HP is calculated. So, the dyno jets are junk and just bought to make a quick buck huh? But some guys know how to make it work right?
Ray@VSK said:Well my car was lean @ low rpms lean & not dynojet mistaken, it was popping & overall just not running as strong as it was supposed to & I had it tuned on a dynojet & it ran great afterwards...
'autoXr1 said:......then you may find areas to improve, especially in the area of part-throttle, cruise, and overall drivability.
tmoss said:'
this is exactly the areas of operation where the EEC adaptive control will create A/F ratios to suit it's own needs (14.7:1) and change any tuning that is done by writing correction factors to KAM and using them to modify A/F in the continuous closed loop operation.
