Dyno results
Today I put my car onto the dyno. It has a under 1000km on the rebuild but its broken in nicely. At first it put down 176 hp and 210 tq. After we changed the jets in the secondaries and set the timing it shot up to 188hp and 223tq. This is on a mustang dyno so that is why the numbers are a bit low. They told me at the flywheel the car has roughly 270hp and 330tq. Its a 306 with E5 heads ported on the exhaust side, trick flow cam, weiand intake with holley 650. Stock headers, off road x pipe with flows and stock 2.25" tailpipes. Im happy with the results especially knowing it still has a lot of potential.
i agree, the mustang dyno numbers are much lower than a dynojet. but the mustang dyno gives a much better tune in my opinion. mine was on the dyno last week my numbers dropped about 75hp from the begining of the summer. i have major major blowby after 4000 rpm's. sad part is mortor only has 300 miles on it. stock heads as well. how much hp do you guys think i will gain with a set of heads? also any recomendations of type? here is my graph.
Correct me if I am wrong but...
I don't know about 25% higher, but the mustang dyno is more accurate. Some cars do better on the dynojet, especially high end hp cars because it only measures the time it takes to spin a big metal drum, kind of primitive if you think about it. A mustang dyno, from what I understand uses actuall resistance to measure power. IOW: basically, if you were to measure how much you could bench press, a dynojet way would be to bench 45lbs as fast as you can, and they would determine how much you could bench from that speed of the bar, while a mustang dyno would actually stack 45lbs plates until you couldn't lift them anymore. So a high horse, low torque (like a marathon runner) would do really well, while a deadlifting bodybuilder (low speed high torque) would not do well. Why do you think Import guys love dynojets so much?
I got a deal because I had my motor built there but I paid 150 bucks for basically 6 pulls with A/F and they helped me tune it (changed the jets, timing). I think if you just want a single run or two its about 60 bucks depending on how many people are there that night. Usually you have to get a few people together and split the cost of renting the dyno or find out when others are having a dyno day.
