dynoed
  • Thread starter Thread starter 2005gtwhite
  • Start date Start date Jul 27, 2007
2005gtwhite
  • Jul 27, 2007
Got my car tuned last friday. I have 390 gears, slp longtube headers, offroad x pipe,slp mufflers, kenne bell 9pis with 15 degrees timing. It would have been better but it was so hot. Was told with better weather i would have made between 420 to 430 hp.
Jenns01TA
37
Jul 27, 2007
  • Jul 27, 2007
Nice #s. Awesome actually considering the run that yielded your max numbers was i taken at 89.66 degrees and 49% humidity.
2005gtwhite
  • Jul 27, 2007
Yeah it was nice but he had just started tuning because the kenne bell tune was too lean.
red05bullitgt
861
Pittsburgh, PA.
Jul 27, 2007
  • Jul 27, 2007
http://s209.photobucket.com/albums/bb160/billedwards71/
After looking at you're dyno sheet ! I noticed, that your dyno tech used standard correction, instead of SAE.. Although, I'm not really sure how standard correction works ? But usually when SAE correction is used ? weather factors, such as humidity and temp, are both compensated and adjusted for in the software..Therefore, you're results shouldn't be affected, regardless of what the weather conditions may happen to be.. But, all in all..you still have very impressive numbers..
2005gtwhite
  • Jul 27, 2007
would have been better numbers at first but that is where he started tuning. The kenne bell tune was too lean.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Jul 27, 2007
  • Jul 27, 2007
Intercooled or non-intercooled? How does that "instant" torque feel
CANTONRACER
885
Cuyahoga Falls, Akron & Canton, OH
Aug 2, 2007
  • Aug 2, 2007
STD & SAE are both corrected...just to different conditions.
Your STD dyno numbers can be compared to his STD dyno numbers because you both correct to the same conditions.
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
HP woes with Sniper Sytem
  • Stang_1973
  • Mar 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
