dynoed
Got my car tuned last friday. I have 390 gears, slp longtube headers, offroad x pipe,slp mufflers, kenne bell 9pis with 15 degrees timing. It would have been better but it was so hot. Was told with better weather i would have made between 420 to 430 hp.
http://s209.photobucket.com/albums/bb160/billedwards71/
After looking at you're dyno sheet ! I noticed, that your dyno tech used standard correction, instead of SAE.. Although, I'm not really sure how standard correction works ? But usually when SAE correction is used ? weather factors, such as humidity and temp, are both compensated and adjusted for in the software..Therefore, you're results shouldn't be affected, regardless of what the weather conditions may happen to be..:shrug: But, all in all..you still have very impressive numbers..:nice:
