Edelbrock 750 carb
  • Thread starter Thread starter Dean85GT
  • Start date Start date Aug 9, 2006
Dean85GT
502
Thorold, Ontario, Canada
Aug 9, 2006
  • Aug 9, 2006
I'm getting a new motor built up with the following specs.
306
Pro-Flo Wiseco forged pistons
Trickflow stage 1 cam
stock heads with the thermactor bumps ground down
Weiand Stealth intake manifold
Stock headers
Now..with the carb decision. Originally I intended on buying a holley 650 DP but the guy at the shop says he has a edelbrock 750 cfm carb that is practically new and I can have for dirt cheap. He says that edelbrocks arent as bad because the carb is progressive and it may work ok. There is a dyno at the shop so we are gonna throw the eddy on there and see if it runs good and pulls decent numbers
What do you guys think? I know the edelbrock carbs are a pain to tune as well.
R
R2D2
Aug 9, 2006
  • Aug 9, 2006
the edel/carter/weber carb is a breeze to tune. The metering rods and orifice plugs are great. Im gonna tell you its too much carb for that stock head. Been there done that 15 years ago. Had a 302 crate motor, GT40 head, performer rpm intake, b303 cam,carter 750. Ran like dog **** regardless what we did. Changed to the carter 600 and was like night and day. Only had to set high idle and the throttle response all therough the range was crisp and smooth.
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Aug 9, 2006
  • Aug 9, 2006
im g0ing with an edelbr0ck 600 0n a 306 with cleaned up st0ck heads, trickfl0w stage 1 cam, 1.7 r0ckers and an edelbr0ck air gap intake. i als0 think the 750 is t00 much carb
R
R2D2
Aug 9, 2006
  • Aug 9, 2006
remember those bad ass max wedge motors from the 60's? What carb did they use? Unless your a serious drag racer or have some serious dollars invested that mandates a serious holley. The edel/carter is an awesome street carb. They also have no chance of leaking like the holley. No mess when changing springs, metering rods etc... People play too much follow the leader
Dean85GT
502
Aug 9, 2006
  • Aug 9, 2006
Soooooooooooo is it not even worth trying the 750? and it seems that everyone is against the holley double pumper. What carb should I go with with mech secondaries and a 4.10 gear.
dragnazz5.0
Nov 19, 2005
815
mooresville, nc
Aug 9, 2006
  • Aug 9, 2006
n0 0ne is against h0lleys but it seems m0st pe0ple hate edelbr0cks f0r whatever reas0n. if y0u want a d0uble pumper than g0 f0r a h0lley but f0r i ch0se the edelbr0ck because they are little better f0r a street car
R
R2D2
Aug 9, 2006
  • Aug 9, 2006
all thats gonna hapen with that 750 is it's not going to work no matter what you do, then you will be anti-edelbrock when in fact the application is not correct and no fault of the carb. Use a 600 carter/edelbrock which are the same carb. Will work kick ass out of the box short of idle adjustment
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Aug 9, 2006
this site has some good info... http://www.jason.fletcher.net/
plus, you can go to the holley site, and they have a carb calculator that should help you out.
I have a 306 with 10:1 slugs, TFS trackheat heads, TFS stage II cam, eagle crank and rods, 1 5/8 shorties, and im using a holley 650dp. so i believe that 750 is going to be complete overkill for your ride. you wont get good throttle response, and it will be a pain in the ass to warm up on cold mornings. thats the one thing i learned, bigger carbs arent always better, in most cases they are worse.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
The Most Preferred Aluminum heads
  • SSnakeGT127
  • Mar 9, 2021
  • 2 3
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 28, 2021
SSnakeGT127
R
Engine Just bought my first 85 fox
  • Rideordie1720
  • May 14, 2019
Fox 5.0 Mustang Tech May 25, 2019
Rideordie1720
R
