efi to carb
  • Thread starter Thread starter stang730
  • Start date Start date May 16, 2006
stang730
56
Long Island N.Y.
May 16, 2006
  • May 16, 2006
What do you all think of the switch? Im considering, going with an edelbrock performance package. Heads, cam, manifold and carb. I was told buy a couple of guys that i would see nice power gains.
vristang
4,933
101
124
Seattle
May 16, 2006
  • May 16, 2006
You will loose any chance of passing emissions.
Carb won't make more power than efi, if both are tuned properly.
Also, efi will be more driveable for the same power as a carb.
At the same power level you will see less fuel economy with a carb.
EFI can provide a very good combo, which is why no auto manufacturer uses carbs.
My opinion.
Don't waste your time and money.
jason
stang730
56
Long Island N.Y.
May 16, 2006
  • May 16, 2006
My opinion.
jason
OK thanks. Next question, the other route i can take, is heads, cam, EFI intake and manifold, and a mass air conversion. Does that sound right? I priced all the parts from edelbrock(performer series), except the mass air which is from ford racing. Or do you recommend other brands?
Spot U 2
21
  • May 16, 2006
Trickflow makes a nice setup. Heads, cam, Roller rockers, pushrods, intake, and vavle covers for around $2100 street heat, or $2200 track heat.
Makes about 360hp on a 9.5/1 306.
stang730
56
Long Island N.Y.
May 16, 2006
  • May 16, 2006
Thanks, do they sell it in a package? Should i go for the mass air also, everyone is sayin yes. would the hp numbers be much different for a stock 302?
Spot U 2
21
  • May 16, 2006
Yes, it comes as a package. Yes you should go mass air. The hp might drop slightly. Not to much diff on a 302 to 306.
stang730
56
Long Island N.Y.
May 16, 2006
  • May 16, 2006
where can i order it?
black92gt
64
PA
May 16, 2006
  • May 16, 2006
Only reason really to go carb is for a bigger motor on a budget, a 351 based or big block engine is very cheap if you put a decent intake and carb on it.. just my two cents, I wouldn't carb a 302 or 306.. don't carb it, blow it.
Spot U 2
21
  • May 16, 2006
Summit has them.
50resto.com is the cheapest I've seen.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
#10
  • May 17, 2006
  • #10
My opinion.
jason
You are right sir but inorder to make the same power with a efi as apossed to a carb its going to cost more.
http://store.summitracing.com/partd...838998+4294858290+4294908331+115&autoview=sku this kit costs $2250
now you have also been told to do a mass air which costs another 320-550 dollars depending on what you need. Now if later you are going to continue to upgrade then the fuel deliver system needs to be upgraded which is going to run you another 150 bucks. then there is a upgrade to fuel rails and injectors. the list goes on and on. As far as drivability with a carb goes they can be just as good. Only troubles i ever have with mine are in coldish weather. You need to allow engine to warm up. I have talked to guys with street avenger carbs in my town driving in same weather and they have no problem. Holley's new street carbs and edelbrocks versions are a far cry improvement. Gas milage yes i agree with jason efi is more efficent. I do believe you will get more power with a carb for less money though
ExplodingGopher
517
The mistake on the lake (Ohio)
May 17, 2006
#11
  • May 17, 2006
  • #11
I wouldn't go carbed, its cheap and effective, but EFI will get better fuel economy and you can tune the living crap out of it. Im even looking to go EFI on my 460, using the 5.0 EEC-IV just re-tweeced.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 17, 2006
#12
  • May 17, 2006
  • #12
if you have the money i agree with staying efi. if not then go carb. that being said keep the efi stuff for when you maybe down the road want to switch back.
stang730
56
Long Island N.Y.
May 17, 2006
#13
  • May 17, 2006
  • #13
Well it looks like im gonna stay with the efi setup. Im gonna go with the package from Trickflow, and the mass air from ford racing. Also id like to add an msd ignition and blaster coil, and mabye a basic nitrous kit, which might have to wait, cause thats pretty much my limit right now
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
