I did the full project on my 89 GT, in the rear of the cylinder heads where the emission tubes hook up you have to remove the pipes, (1 on each head that go to a "Y") cut the end pieces off, reverse them and install on the opposite head you removed them from so they act as caps to block off the holes.I put a billet egr eliminator plate on that was about 1/2" thick, all it was ,was a place to connect the throttle linkage.BIG MISTAKE!!!!!! the stock linkage was hitting the heater tube located above my intake between the upper and lower plenum,I eliminated the heater tube but still,the linkage throttle cable was at a confangled placement and my throttle got stuck OPEN FULL BLAST! on multiple occasions causing me to have to turn the key off and roll to the side of the road, pop the hood and pull the linkage closed.Really scared me the first 3 times HAHA.I ordered the cap off plate that bolts directly to the back of the stock EGR plate and I was so happy....also when you eliminate the heater tube you will be running all over looking for hose fittings.In my opinion.....Get the cap off plate and leave the EGR plate. It may save you a world of headaches....I hope my Horror story helps you and good luck
