emissions help 347 stroker
  • Thread starter Thread starter lxwants12's
  • Start date Start date Nov 16, 2005
lxwants12's
506
  • Nov 16, 2005
I live n phoenix and there emissions here...i need to know what kinda of adjustments to make and help me pass.....fuel pressure to run?? timing?? my car failed not horribly but it failed the gas part....and i need to know what are the general tricks for making a car pass...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 16, 2005
  • Nov 16, 2005
What do you mean the gas part? Too many hydrocarbons? Are you using any sort of tuning device at all? What cam are you using in your engine? That may play a big part in your emissions, too.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 16, 2005
  • Nov 16, 2005
How to pass emissions testing:
1.) Make sure all the emissions gear the car was made with is present and connected up properly. That includes a working smog pump and cats.
2.) Make sure that you have fresh tune up with spark plugs, plug wires, cap, rotor, fuel & air filters. An oil & filter change is a good idea while you are at it.
3.) Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/article...c-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/det...iption.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
4.) Post the codes and get help to fix them. Don’t try to pass with codes not fixed. Clearing the computer just temporarily removes them from memory, it doesn’t fix the problem that caused the code to be set.
5.) Be sure to do the testing on a hot engine. Drive for 15-20 minutes prior to taking the test to get operating temps up into the normal range. Do not shut off the engine while waiting for your turn on the test machine. An engine up to full operating temperature puts out fewer emissions.
Sicarius428
2,085
Nov 17, 2005
  • Nov 17, 2005
The lower the timing is the better the emmisions are suppose to be. Try to set it at 8* because if it's anything like Kali, it's suppose to be set at 10* but you can probably get away with 8*. Run regular fuel if you can with your engine(don't destroy the engine). The lower octane will create a more explosive(ping) and less burn... leaner running basically. Drive the car moderately hard for 30 minutes before you smog. The cats take a little time to warm up to operating temp. The hotter the cats are... the more efficiently they will work. MSD box if you don't have one is suppose to really help. My friend failed once and threw one on and it passed with flying colors. He now swears by it but don't take my word for it. Make sure your cats are in working order. If you have the stock cats they might be going bad. Magnaflow makes a carb legal x pipe if yours aren't up to the task. Hope it helped.
Kevin
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
