Yea, that green glass filler is TOUGH stuff. It will hold up.
Use the filler from the back side and put a piece of tape over the hole in the compartment and it wont need much sanding or filling when dried. Just a thought.
Try to use the filler with the long strands the top coat it with the regular bondo. It will last longer.If you don't weld it.
What about all those dimples on the firewall....the ones that arent actually holes. Would the bondo hold up on those?
