Engine quits without warning???
  • Thread starter Thread starter sixty5pony
  • Start date Start date Jul 13, 2008
sixty5pony
14
  • Jul 13, 2008
Any thoughts on this? I have 65 with a 302 in it with an A/T. It's running great. Starts up right away, idles nice and smooth around 600rpm and cruises around town with no problems and even runs cool in 100 degree summer weather around 190 - 210. But then without any warning, i'll be sitting at a red light or maybe stopped in traffic and it suddenly dies. It'll do this maybe 2 or 3 times throughout a typical drive around town. The idle doesn't struggle as if it's going to die, it just cuts off all of a sudden. I start it up, put it in drive and off i go and it won't do it for a while and then maybe a while later it'll do it again. Could it be a timing issue? As i said, aside from doing this every now and then, it runs like a champ.
any ideas?
Tim65GT
1,149
West Texas
Jul 14, 2008
  • Jul 14, 2008
I was going to say crap in the fuel line, but you say it suddenly cuts off with no spitting or sputtering?
Maybe a loose wire or ign switch contact in the coil circuit?
woodsnake
1,352
15
69
Hicksville, NY
Jul 14, 2008
  • Jul 14, 2008
Worn out ignition switch, where the key goes in. Next time you fire it up, try and move the key around, up and down and see if it dies...
M
MitchGT
204
Jul 22, 2008
  • Jul 22, 2008
If your tranny is in neutral, does it still do it?
D
D.Hearne
11,730
south louisiana
Jul 22, 2008
  • Jul 22, 2008
If someone added a tach to it, check the tach wire (green wire) that runs from the coil to the tach. Any little break in the wire and if it touches a ground, it'll kill it instantly.
sixty5pony
14
  • Jul 28, 2008
Looks like i had a loose tach wire. thanks for the help, nice job
D
D.Hearne
11,730
south louisiana
Jul 28, 2008
  • Jul 28, 2008
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
