Engine sludge treatment?
68keyblr
Mar 17, 2003
946
20
49
Arizona
OK so my 5.0 has 160k on it now. I'm planning on rebuilding it this fall but need to drive it until then.
I know there is some serious sludge in this engine - the PO apparently wasn't all that meticulous about upkeep on this car and oil changes must have been sporadic at best.
So the question is, should I do a sludge treatment? If so, what should I use? I'm afraid that I'll remove some sludge that is plugging up oil leaks and maybe remove sludge from the rings that's keeping oil consumption down.
So, what say ye?
Using a full synthetic will also get rid of the sludge. It's a detergent oil which might clean away some of the sludge which is keeping your seals from leaking. hehe.
Kevin
Do you think you have a layer of paraffin in the bottom of the sump or something?
If you are going to tear the motor down in one or two OCI's anyhow, I'd wait.
BTW, the ring seal aspect you addressed isnt an issue.
Just MHO.
Good luck.
You know there is sludge, or do you just suspect? You can do some pretty horible things to modern engines and modern (petroleum)oils without seeing the same breakdown and varnishing as pre-'80s stuff. If the engine runs fine right now, just put some cheap petroleum oil in it and drive until the rebuild.
If the motor is running half way decent now, I too would not mess with it. No point in taking chances before a rebuild.
Changing the oil while it is still hot should help clear some crap out of there.
On a side note...
In talking to some of the "old timers" that I know, I have heard of using 1qt of ATF in an oil change to help clear out the sludge. ATF has some serious cleaners in it.
As I heard it, you are supposed to replace 1qt of oil with ATF, run the car up to temp (but not load the engine, sitting at idle is good), then change the oil and filter. Most of the guys who have done this also recommend changing the oil/filter again, after a short drive.
I am not saying you should do this.
I only bring it up to here what others have to say.
I have tried it in a 2.3t engine I just swapped into my LX. The motor had been sitting with with the head removed for who knows how long. All seems well with that motor so far, but I have only driven ~100 miles since.
jason
I think that there is a higher chance that a sludge treatment will hurt than help.
I've never expereinced a problem after using one (tried it once) but have CREATED two bigger leaks out of smaller leaks from using a seal conditioner (used twice 2 for 2 failure). My dad said he used a seal conditioner on an auto tranny hat was leaking very badly and it slowed the leak considerably.
It seems that when used preventatively these products cause problems but when they are used as a fix they MIGHT work.
Just my 2 cents.
