Build Thread Enola- Finishing touches
If you are doing a complete brake swap over including the prop valve, then do yourself a favor, and get the one wilwood sells that also has the proportioning valve and bias adjuster combined as a unit.
As many spacers as I have piled on top of my 94 drop leg spindle to try and correct bumpsteer, a pair of 96 units would’ve cut that down by half. I think you’ll be good going with them.
  • Useful
Reactions: General karthief
Looked around for hours last night trying to find a fitment chart... does anyone know if there is a resource page somewhere.
Also I need to know if these axles will allow for proper backspacing on the rear tire. I want to try and fit a 285 on a 10" rim with cobra disk brakes
This was a thread I came across. Not sure if there is any difference in hub center size between fox 4 lug and 5 lug axles. Seemed legit...and cheap.
That is a cheap option for the brackets. I need to check the axle we have and see what it has hanging on it. We are going to leave that one be as its getting used in a falcon project.
I just need to decide on the GT rear brakes or Cobra.... I like the idea of the larger rotor for looks but if it is unnecessary for the extra cost, then there are the taurus calipers.. I need to figure out what brackets I need if I decide to run those and what the benefit is. I have a partial parts list so far, I need to figure out what soft lines I need for the front and rear as well.
@Mustang5L5
Don't the 93 Ford Taurus rear Caliper directly swap for the sn95 rear Calipers? Do they fit the V6/GT smaller rotor or have to use the larger Cobra rotor?
Figured this would be the best setup these days. I have been thinking of getting these rear calipers to replace the standard V6/GT calipers I have now
@Mustang5L5
They will fit either the GT/V6 setup, or the Cobra setup. It's a good option to use the smaller rotor, but still retain decent rear braking power while clearing 15" wheels.
The downside is you need to upsize your MC about 1/16" going from the 38mm to the 43mm rears. If you are running ATS fronts with the 43mm rears, you will need the 1 1/16" MC from a 94-95. I know of someone trying it with the 1" 93 Cobra MC and finding they ran out of pedal and needed to go larger.
The downside that many are finding out about the ATS brembos however, is that they usually require a spacer to clear certain wheels due to spoke clearances. That's why I haven't installed mine (other than the car being down) is because I am not sure they will clear the aftermarket wheel i have in mind.
I have a small lathe and plan to cut the ears down to get the correct placement over the rotor, I dont mind running a spacer as long as the wheels fit... or I can make them fit, then car needs paint so If I have to move the fender I will.
I have a 93 MC on the way so that pretty much locks me into the GT rears, I will want them to fit a 15" rim in the off chance I borrow a set of real tires at the track.
Thanks.
I don't know what to think. All this 'can I use this if my that fits I use a lathe to turn another that down so something else can be used if I need to because that needs to be bigger if this is put on backwards on tuesday'.
I have a headache and it ain't even my car!
Thats ok JR, you just need more coffee.
I now have 90% of what I need on its way to the house, I still need to order the axles I posted above... only a few things I still am uncertain on.
-what rear brake lines do I need and will I need an adapter
-what front brake lines do I need and will I need an adapter
-I want to run a fairly large tire up front, what A-arm will work best/give me more clearance, I am assuming MM but figured I would ask.
Ok. I am pretty sure you can, but you have to make modification to the factory reinforcements which are basically pop riveted in at the factory. I have never done it on my car but I have seen it done on other convertibles. On the subframe connectors same deal, I had to modify the factory reinforcement panels when I welded in my connectors.
Reactions: 2Blue2
I have a massive list of parts on the way to the house.
-31spline fox length axles with 95 flanges
-new 31spline FordRacing trac lock
-cobra 38mm calipers
-11.65" rotors
-needed brackets for the calipers
-new hoses for the rear, I plan to cut the factory lines and flare with a proper fitting
-ATS calipers
-13" rotors
-96 spindles
-new hubs
-93 cobra booster
-prop valve and plug
- line adapter
I think that's everything I need
Rims and tire are to be determined
-11.65" rotors
-ATS calipers
-13" rotors
-96 spindles
-new hubs
-93 cobra booster
- line adapter
I’m glad it’s not just me spending money like there’s no tomorrow here...I feel so much better.
