i heard that equal length headers aren't as efficient as unequal length shorties on a stock motor...is this true? thanks in advance.
Matt
Matt
Michael Yount said:While your motor mounts may not have been sagging, I believe the convertible mounts cause the engine to sit lower than it normally would. People use them intentionally for this effect when they're trying to get more hood clearance for superchargers, spacers, etc.
Michael Yount said:Actually, you have to look closely at the data on the test in the current issue of MM&FF. They tested equal and unequal shorties, and 1 5/8 and 1 3/4 long tubes all by the same maker. For peak power, there was very little difference between any of them - I think a 4HP spread - and the shorties actually made one or 2 more HP than the long tubes did. However, look down the charts at 3000 rpm where they started recording data. The long tubes made 20+HP and almost 40 LB-FT!!!! more than the shorties - a HUGE difference. I suspect that difference may be even greater below 3000 rpm, but they didn't show the data. The amazing thing is, the article didn't even highlight those differences. According to their tests, there wouldn't be a whole lot of difference between long tubes and shorties on an engine like theirs with the rest of their exhaust system configuration AT PEAK. But for street driven cars that spend the vast majority of their time below 3 grand there is a huge difference. If you don't mind the inconvenience of the install and the greater cost (especially ceramic coated) the long tubes are the way to go.
