  • 1994 - 1995 Specific Tech
Explorer Intake Mani ?
  • Thread starter Thread starter putertopia
  • Start date Start date Oct 20, 2009
P
putertopia
31
South Central PA
Oct 20, 2009
  • Oct 20, 2009
So I've searched for this for about 45 minutes, and I haven't found one thread actually answering the OP's question of 'Will the explorer upper and lower intake bolt onto a 95 GT with no other changes?' without everyone instead debating about the performance of the explorer vs. cobra, etc.
If you know of a thread, please, just post it and I'll check it out.
Will an internal EGR explorer intake (is it 97 and older explorers?) bolt right onto my 95 GT w/ 70mm BBK TB, or will I have to mess with my BBK adjustable FPR, MAF, or PCM? I understand there are some slight clearance issues, but also understand that this can be remedies with the removal of the hood liner? Is that a good idea for a daily driver? I'm worried mostly about outflowing my MAF and don't want to have to pay for tuning until I'm out of college and really start modding this thing.
I don't know why the PO has the 70mm BBK TB on there now with stock intake/heads/exhaust manis. Does have BBK H-pipe w/o cats and flowmaster exhaust, BBK adjustable FPR (that requires me to prime 3-5 times before start), but still not enough in my eyes to warrant a TB upgrade.
I want some cheap power here with minimal extras. As of right now with the larger throttle body, I feel as though she might be getting too much air, as the car ALWAYS hesitates in low RPM for a few seconds the first time you gently launch into first. No matter how warm it is, it's like the MAF has to re-calibrate, but then it runs just fine after that.
Oh, and what's so special about the SN95 intake elbows? Why are they so expensive?
Thanks guys!
Adam95GT
2,564
Burlington, NJ
Oct 20, 2009
  • Oct 20, 2009
Yes it will bolt strait on just need the elbow. 95's dont use an internal style egr set up.
and what do you mean by out flowing your maf????? who told you this? there is no way your going to peg your stock maf with just an intake swap... even with HCI you dont really peg the maf. Bigger injectors cause you to change to a calibrated maf or get your car tuned.
P
putertopia
31
South Central PA
Oct 20, 2009
  • Oct 20, 2009
Thank you .
I was reading somewhere I think on corral about MAF. I plan on supercharging a fresher built motor after I get out of college for this car, so mods will be limited to light bolt ons until then, because that will be $$$.
When would I need injectors? If I get a good deal I may go GT40 heads and a cobra cam (or SLIGHTLY more aggressive aftermarket that won't need tuning if possible) w/ cobra PCM (per suggestion of someone on here I think) too.
Adam95GT
2,564
Burlington, NJ
Oct 20, 2009
  • Oct 20, 2009
putertopia said:
Thank you .
If you want to go with a cobra ecu (J4J1) you would need to go to 24lb injectors as thats what the ECU is calibrated to deal with...
Wait for HCI or a power adder to upgrade your injectors... a mild HCI you will be fine with 24lbers.
79'293stang
505
11
29
Cedar Rapids, Iowa
Oct 21, 2009
  • Oct 21, 2009
Yea its a direct bolt up with the elbow. I just laid my two intakes side by side and stole the fittings off the original and put them on the explorer and got a plug kit and cut off and capped off the extra vacuum line connections.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 21, 2009
  • Oct 21, 2009
No point in buying a cobra PCM. The hardware is the same. Put that money towards the moates quarterhorse. Upload the Cobra tune. Bam...you have a cobra PCM. And...you're ready for future upgrades.
P
putertopia
31
South Central PA
Oct 21, 2009
  • Oct 21, 2009
Yeah I just realized that today. I need the quarterhorse (which is out of stock?) and the Binary Editor, correct?
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Oct 21, 2009
  • Oct 21, 2009
Its really personal choice on software.
And yea...looks like they dont expect more until nov. 15
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
