Congrats Nik, those are some petty solid runs. Now fix the traction issues, and then it will be time for somemore extra piping to feed that engine.(Turbo)
Those are good times, especially considering your 60ft and mph. Just curious, what is your mph in the 1/8?
I had the timeslips with me this morning, but I took them home on my lunch break. I'll try to remember to look at them and answer your question tonight.I guess my question isnt valid..How come i went an 8.5 in the 1/8 had an 1.88 60ft ran a 13.3 @ 103 mph why was my top end low...Is it weight?...is it because my timing is set low....Meth flooding on top end..Just curious because im running what you are and probably can run better i have traction....I didnt even take air out of the Mickey thomspon ET street drag radials i was running...My car does weigh 3778 lbs is that a factor?
I've plugged it into a couple calculators on the interwebs, I'm getting something like 335-337 to the tire, which is right about where I expected the car to be.
I have zero faith in those HP calculators. Every one i use tells me i have 500hp.
His car ran the back half faster because it is making alot more horsepower than your car, the weight of your car is definitley not helping
..I dont think im developing it on top end...My 1/8 and 330 on my slips are compared to 12.3 can that i ran againt.... I seem to be losing it a little after the 1/8 mile..I am supercharged i should be pulling better on top not on bottom..Im thinking my timing is to conservative..Im running 21 degrees total Locked...and running a stage two snow performance water injection kit...From which i was told by the supplier he is making me run rich...so i made some adjustments on the control box and i will play with timing...I think i should be in the 12's i ran a 1.88 60ft on drag radials at 29 psi and i did spin a little....So I should gain not making it as rich, i should gain ET and mph no?I have zero faith in those HP calculators. Every one i use tells me i have 500hp.
Calculating horsepower from MPH and weight is much more accurate IMO than a chassis dyno.
Awesome times for an untuned car. Congrats!
You gonna put a wideband on the car?
Haha, you get a chance to pull them out last night?
