Just bought a set of 58cc stud-mount AFR 165's with the upgraded valve springs and seals. They only have around 200 miles and still look new! Saved a bunch of money over brand spankin' new ones (thanks Jesse!
) and even got a set of free head gaskets. I'm excited!
Last summer when I got my Thumper heads, I took a lot of crap from a lot of people here for buying "hogged out crappy E7 heads." Well those crappy ported E7's made a huge difference in the way my car ran and I was very happy for the (relatively) small amount of money I spent. I've never ridden in a car with AFR's, so all I can say is when I take the E7's off I better feel a HUGE difference from the old tried and true irons. I know AFR's are better engineered and it will be nice to lose the weight on the nose, but I want the budget racers out there to know that a good set of ported E7's WILL make a considerable difference if you can't afford aluminum heads and still want to have a quick daily driver. GT-40p's are another excellent option for someone who wants to go fast cheaply. I guess all I'm saying is that yes, I know E7's were designed more for economy than performance, but they can be made into a respectable head as Thumper or any good head porter can prove.
I didn't get an FTI cam, which will be considered a sin by many of you I'm sure...but after reading about some of the headaches trying to get those cams running I just didn't want to run one at this point. I want more airflow without sacrificing drivability and heads will give me that while a different cam might not without some supporting mods. It seems like most of Ed's cams come with low LSA's, which our cars do not like, so that $325 custom cam would turn into a $1000 cam after I bought a TwEECer or custom chip to get the thing to idle right, plus paid extra for the cam install (I don't have my own tools, garage, or anything needed to disassemble an engine).
I know an FTI cam would maximize the combo, so I may order one later down the road but I'd have to have a guarantee that I'd pick up a ton of power under the curve over my current cam before I'd consider it worth it. I'm very happy with the powerband of my XE270HR so I'm hesitant to ditch it. The car should be firmly in the 12's by just adding the heads, assuming I can plant the power and drive, and that's enough to pull on those pesky LS1's that I'm currently running right beside of (thanks Thumper!).
I ordered some supporting mods...24# injectors, Pro-M 77mm, etc. I know I'll need hardened pushrods which I'll have my mechanic measure for, as well as stud mount roller rockers. Which roller rockers does everyone recommend? I'm considering Trickflow, Harland Sharp, and Scorpions although I had bad luck with my pedestal mount Scorpion 1.6's...my new Crane 1.72's have been fine.
Also, do stud mount rockers need taller valve covers? I'm not running the 94/95 stockers...I'm running a set of Fox VC's.
So...do you guys think I'm in for a treat once we slap on those AFR's? I read that adding just a set of AFR 165's on a stock 302 made 40hp over stock E7's!! That's awesome...and I've got a free flowing intake and exhaust so I can only imagine...just hope I'll be real happy with the difference.
I dont have the patience for blown HG's and chasing the 100 possible causes down.
