Finally ran my car...
KTD SC
99
New York
I went to Lebonon Valley Raceway and i finally ran my car. It was pretty humid, but not to hot.
R/T - .678
60 - 2.552
330 - 6.465
1/8 - 9.664
MPH - 76.77
1000 - 12.409
1/4 - 14.710
MPH - 98.07
Is this good? My reaction time and 60 foot sucked ass, i know that
But other than that, it that good for the mods i have?
Yeah I would say you can do quite a bit better with your mods with some practice. The MPH is great and you can definitely get closer to 14 flat with that MPH. Get some drag radials and you'll cut those 60's times for sure.
Dont want to steal the thread but theres always too many "how'd i do" threads and i wanted to post my times :D no point in startin another thread. this was the first time i've ran my car at the track
r/t- .670
60'-2.212
330-6.188
1/8- 9.514
mph-74.42
1000-12.362
1/4-14.774
mph-93.69
my 60ft was decent for my first time but why was my MPH so low?? :shrug:
You know that does seem like a slow mph. Because my car ran 15.2 at 91 when it was bone stock. So it seems like with the smog delete long tubes and h-pipe you should have done a little better than that. How many times did you run. Was that your best MPH??
I ran three times, and all of them were 93.sumthings. 93.69 being the best. I was having a little trouble with the shifts, still not used to the TKO600 so that probably hurt me a lot
I have the same question about low MPH. My latest pass was:
.511 RT
1.964 60FT
5.942 330FT
9.304 1/8 ET
73.16 1/8 MPH
14.651 ET
92.02 MPH
I asked this question in the past but the best answer I got was because I was running 4:10's. M yonly problem with that response is I'm crossing at 4,000 RPM's so I don't think the gears are the problem? If anything I think I shoul dhave 4:30 or higher? I's an AODE vert in full trim so it weighs a ton. My mods are:
4:10's
B&M 3000 stall
1 5/8 shorties
2.5 h-pipe, flowmasters and 3" dumps
UD pullies
JMS custom chip
.511 RT
1.964 60FT
5.942 330FT
9.304 1/8 ET
73.16 1/8 MPH
14.651 ET
92.02 MPH
4:10's
B&M 3000 stall
1 5/8 shorties
UD pullies
JMS custom chip
I would say your problem is just the weight. Like you said verts weigh a ton. But good ET though. How do you like that 3000 stall?
Verts don't weigh as much as people think. They only weigh a little above 3400 lbs. The only weigh about 100 lbs. over a coupe. Which is only good for about 1/10th in the 1/4.
