After a few delays and waiting to get all the parts the Mustang is finally going into the shop today for the new parts install
Here is a list of everything going on.
Trick Flow R intake (351W)
1" spacer
Ed Curtis FTI Camshaft
LSX Valve springs
Camshaft Thrust Plate
Abaco 97MM Mass air meter (arriving tomorrow)
C&L True flow tube
#36lb Injectors
Autolite Spark Plugs
New cap & rotor
mitstomuto 2 core aluminum radiator
Ford Racing black powder coated tall valve covers
Double roller timing chain
New fuel filter and Transmission fluid
It should be done in about two weeks and then its off to the dyno for some new numbers and a tune then its back to the track to see what improvements I can make w/the new combo
Here is a list of everything going on.Trick Flow R intake (351W)
1" spacer
LSX Valve springs
C&L True flow tube
#36lb Injectors
New cap & rotor
Anyway the process is going along well and if it continues I could have it back next week.
