Hi,
Im new to 5.0 but in no way new to engine rebuilding. Yet im a newb to superchargers, so i have a few questions before i start. Im looking at a vortech kit with an SC-Trim charger. List of items is as follows...im looking for info on what other parts ill need or what i should change.
Accufab 70 MM intake + Spacer
70 MM? (or 80?) MAF (dunno what brand to go with...)
34# Injectors at minimum
200+ lph fule pump
Cobra upper + lower intake or edelbrock Performer 5.0 Pro II?
Under drive pulleys (can these be used with a supercharger?)
Headers (what is a good brand? torn between BBK and Edelbrock? open to suggestions), Flowmaster 40 series, X-Pipe.
Cam, now i have no idea on what cam to get. Heard good things about the E303 but people say theres better cams out there...? Comp cams maybe?
im looking to run between 8-10 PSI on a stock bottom end...is this safe? or should i be looking to rebuild the bottom end? Also, what other parts would i need? Any help is much apprectiated, if you need any other info just let me know thxs again!
200+ lph fule pump
