EGR is on the passenger side!
No GT40P aftermarket header will have the EGR outlet in the pipe. None of them. You will never find a set to do this.
You have these options:
#1 and most popular is to ditch the EGR and get the headers I mentioned above or a set you know 100% will fit. There are already discussions on here for eliminating EGR. Screw the EPA, global warming is a myth anyway and the mileage is not that much better. Yea I know, there are pros and cons, but this is a GT40P situation.
#2 Get the headers above and place the bung from your stock headers on their somehow and make that pipe work with them. You can buy the tubing and a flaring tool and make your own pipe. Will involving welding, but not impossible. This method is the hardest.
#3 Use 1 factory EGR header that I already told you will work, and then use one GT-40 P header from the ones you will have to buy for the drivers side. This is the stupidest choice on planet Earth. I can not believe I came up with it. I would not do it, but you wanted some options, and you seem like your desperate to keep the EGR. People, will he do it??? Tune in tommorrow....
As you can see, your screwed just about anyway you go here because your spending money on the headers one way or another, on all 3 choices. When you go changing things like heads and such, you have to accept that not everything is going back the same way. EGR elimination is the best choice, and I would welcome anyone else's options. I would stay clear of the GT40p's man, I got them and I am warning you, it has not been fun. Dont say you did know when your fists go flying and you start cussing like a drunken soldier......................
