Compromise: Roots type/Manual trans, which is precisely why the GT500 comes with the roots style...it is a compromise car. Heat soak less w/roots, torque more than centri.
I'm not sure what you mean by "compromise"? If by that you mean they aren't willing to "sacrafice" reliability, durability and longevity for performance, then I guess yes, the Eaton is a compromise.
All blowers will effectively increase the static compression ratio. That's the point of forced induction.TVS: designed for lower compression pistions in GT500 (double digit boost). GT is high compression engine, stay with blowers designed for this.
For stock pistons/drivetrain stay with single digit boost. Double digit boost will stress stock bottom end and drivetrain.
If breaking the bottom end due to too much compression is a concern, you can always dial the boost back with pulley size. The 3rd Generation Eaton-up and TV series are probably the blowers the most desirable if that is the case.Dialing back the pulley size on a centrifugal will produce the desired results, but have will have a negative effect on the power curve. Torque and horsepower will ramp up slower and later than in would with a properly sized pulley.
Doing the same thing to a Twin Screw doesn't hurt low end torque productions so much (because of its Positive Displacement nature) but twin screws aren’t happy unless they’re spinning hard! Because of their typical 1.35 internal compression ratio, running a Twin-Screw compressor (especially of the larger variety) below its efficiency level like that actually increases discharge temperatures, which is nearly as bad as running excessive boost to begin with. Heat can be controlled with intercooling though, but cruising temps are still higher regardless.
3rd, 4th and 5th Generation Eaton’s although unhappy when being spun hard are actually more efficient than either the centrifugal or the twin screw at slower speeds. They still move plenty of air down low so torque and horsepower don’t suffer, but since they don’t compress the air, excess heat isn’t a problem.
Like the earlier Eatons, the same can be said for the TVS. No internal compression takes place within the unit itself (unlike a Twin-Screw) nor is the air being compressed under normal driving conditions (also unlike a Twin-screw). Flow rates and efficiency levels and with them discharge temperatures are improved over the standard Eaton, which will allow a drop in blower speed, without the negative effects of the other two blowers.
